Pagina 9 di 50 primaprima ... 789101119 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #81
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    cm13 is under heavy development...so for the moment some things don't work or work badly
    for sim detection you have to add this patch to cm13 source
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    some users have told me that td-scdma and China telecom still not working...I don't know why (I'm in Italy so i can't do test )
    what do you mean with "How do you integrate the official baseband into the system" ?
    How can you provide the source of these added? Can you talk about the appropriate command or method? I mean, how to integrate the official baseband into CM13.
    Nov 2015
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    Is the four code need to be replaced? I download, look at these four things are the same?
  4. #83
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Hi Paolo.
    I've been following this thread for the last two weeks and finally yesterday I upgraded to your new and flawlessly CM13.
    My impressions:
    - Great job. I never thought when I bought my Z7max one year ago I would ever see Android 6.0. Amazing! :-)
    - Performance in general is good. No major differences with your CM12.1.
    - Surprisingly, no major bugs. I told you when you release CM12.1...change alpha for beta. At least alpha4 should be called beta1. :-)
    - I still miss some CM12.1 personalizations, like, for example, inboud/outbound data usage in status bar. I suppose Cyanogen team has to port from CM12.1 to CM13 many things.
    - No major enhancements in battery life. However, yesterday I was touching a lot my device. Let's see today how do battery performs in real life.
    - Some apps do not work. Obviously, they have not been upgraded to work with Marshmallow.
    - Nubia camera does not work... but YiOS camera yes! Much better than stock CM13 camera. ;-)
    My congratulations for your great work. As usual, count with me as alpha/beta/release tester!
    By the way, where can I download Baseband 3.65? They have dissapeared from your MEGA account.
    Thank you!
  5. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (17-11-15)
  6. #84
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Hi Paolo.
    My impressions:
    Thank you!
    yes, for now some things still missing in cm13 but cyanogen team works hard to port everything
    where I can download the Yios camera ? (you can upload the apk ?)
    you can find all baseband here: z7max_baseband
    Nubia Z7MAX
  7. #85
    Quote Originariamente inviato da awssong Visualizza il messaggio
    These are patches so you have to apply to the cm13 sourcecode
    a little guide how to apply patch: http://forum.xda-developers.com/show....php?t=2763236
    Nubia Z7MAX
  8. #86
    Nov 2015
    Thanks!
    I want to try to learn some Chinese menu, which is finished on file?
  9. #87
    Nov 2015
    Thanks!
    HI, POLO, I press your method, the first compilation of success, SIM card also has a signal, but after I second times, according to the same method in the compiler errors, the specific error is as follows:
    frameworks/opt/telephony/src/java/com/android/internal/telephony/TelephonyPluginDelegate.java:66: 错误: 找不到符号
    .getString(R.string.telephony_plugin_class_name);
    符号: 变量 telephony_plugin_class_name
    位置: 类 string
    frameworks/opt/telephony/src/java/com/android/internal/telephony/TelephonyPluginDelegate.java:67: 错误: 找不到符号
    String libPath = context.getResources().getString(R.string.telephon y_plugin_lib_path);
    符号: 变量 telephony_plugin_lib_path
    位置: 类 string
    注: 某些输入文件使用或覆盖了已过时的 API。
    注: 有关详细信息, 请使用 -Xlint:deprecation 重新编译。
    注: 某些输入文件使用了未经检查或不安全的操作。
    注: 有关详细信息, 请使用 -Xlint:unchecked 重新编译。
    2 个错误
  10. #88
    you have added other patch ?
    Nubia Z7MAX
  11. #89
    Nov 2015
    No, only to replace the one you gave me a folder, no synchronization source code can be compiled, but after the synchronization, clobber make then compiled on the wrong.
    Users have provided me with a file (customize.xml),
    <resources>
    <!--Fully qualified class name of the plugin which would be
    dynamically loaded by TelephonyPluginDelegate-->
    <add-resource type="string" name="telephony_plugin_class_name" />
    <java-symbol type="string" name="telephony_plugin_class_name" />
    <string name="telephony_plugin_class_name" translatable="false"></string>
    <!--The locatiotion of .jar file which has the extended implementation
    of telephony base classes.-->
    <add-resource type="string" name="telephony_plugin_lib_path" />
    <java-symbol type="string" name="telephony_plugin_lib_path" />
    <string name="telephony_plugin_lib_path" translatable="false"></string>
    <!-- Support for disabling to fetch APN from OMH card
    for some cdma carriers -->
    <add-resource type="string" name="config_fetch_apn_from_omh_card" />
    <java-symbol type="bool" name="config_fetch_apn_from_omh_card" />
    <bool name="config_fetch_apn_from_omh_card">false</bool>
    </resources>
    I am compiling, I do not know will not be reported to the wrong.
  12. #90
    sorry but I not have any issue to compile the rom
    so something must have gone wrong when you put the patch
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    jadar (20-11-15)
