Pagina 8 di 50 primaprima ... 67891018 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #71
    Nov 2015
    Can you share the contents of your local_manifests file?
    Quote Originariamente inviato da awssong Visualizza il messaggio
    I re sync the code you provide alpha 4, China Telecom, China Mobile is still no signal? How do you integrate the official baseband into the system? Can you tell me how to do it? Thank you
    cm13 is under heavy development...so for the moment some things don't work or work badly
    for sim detection you have to add this patch to cm13 source
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    Gerrit Code Review
    some users have told me that td-scdma and China telecom still not working...I don't know why (I'm in Italy so i can't do test )
    what do you mean with "How do you integrate the official baseband into the system" ?
    Ultima modifica di PaoloW8; 16-11-15 alle 19:17
    Nubia Z7MAX
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (16-11-15)
  5. #73
    is like your
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    Pstelios (16-11-15)
  7. #74
    Nov 2015
    I have China Mobile card in sim 2 but I am not in China too. So far 4G LTE (sim1) and GSM roaming (sim2) in HK are okay.
    I can test the TD-SCDMA this weekend. Have you tried using *#*4636*#*# to force a TD-SCDMA only connection ?
  8. #75
    Quote Originariamente inviato da owhk Visualizza il messaggio
    with the our kitkat radio the new (marshmallow) command RIL_REQUEST_GET_RADIO_CAPABILITY doesn't work so we need to set statically which bands the modem support
    in alpha4 I have added the td_scdma support (in addition to GSM, WCDMA, LTE etc) so maybe now works
    Nubia Z7MAX
  9. #76
    Nov 2015
    It reminds me one question, when I used Samsung S2 and Note2 years ago, their network search order were from high to low, that is from 4G 3G then GSM. When using Z7max, it seems like searching network from GSM up, please correct me if I am wrong.
  10. #77
    it would seem so, but I think it's just an impression
    if you set GSM/WCDMA/LTE I think that first try with LTE then WCDMA and last GSM
    Nubia Z7MAX
  11. #78
    Nov 2015
    Not really ture, I never see my Z7max search network from 4G down, no matter which ROM I use, it always search from GSM up.
  12. #79
    Nov 2015
    How can you provide the source of these added? Can you talk about the appropriate command or method? I mean, how to integrate the official baseband into CM13.
  13. #80
    Nov 2015
    On the signal switching, you can refer to the modified method of CM12.1.
