Pagina 13 di 50 primaprima ... 3111213141523 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #121
    Nov 2015
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    Seriously guys, stop rushing Paolo. He's not ZTE support and he provides this ROM in his free time. We should be very thankful to have someone like him working on this, not harass him every day for updates.
    Thanks for the great work Paolo
    OK!Everyone should thank him!
  2. Il seguente Utente ha ringraziato awssong per il post:
    jadar (23-11-15)
    Oct 2013
    You're right.... +1
  5. #123
    link and changelog alpha6 in first page
    Nubia Z7MAX
  6. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    inigoml (25-11-15),jadar (23-11-15),mai62 (23-11-15)
  7. #124
    Sep 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Grazie, maestro
  8. #125
    Nov 2015
    fatal: duplicate path hardware/qcom/fm in /home/syai2012/android/cm13/.repo/manifest.xml
    What is the problem?Paolo
  9. #126
    Nov 2015
    reserved 1
    I found this file in this code has a problem, delete the synchronization to continue.Where is the error?Paolo
    local_manifests.xml
    <project name="CyanogenMod/android_hardware_qcom_fm" path="hardware/qcom/fm" remote="github" revision="cm-13.0" />
  10. #127
    Nov 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    local_manifests.xml
    No updates are good before.
  11. #128
    Nov 2015
    WIFI Alpha6 will not automatically link.
  12. #129
    Nov 2015
    Like and manifests directory default.xml repetitive, notes I fell inside the default.xml (<! -- <project path = "hardware/qcom/fm" name = "CyanogenMod/android_hardware_qcom_fm hardware CyanogenMod/android_hardware_qcom_fm FM" groups= "qcom, Qcom_fm FM" / > -- >), so that you can do?
  13. #130
    local_manifests.xml
    delete this line from your local_manifest
    Nubia Z7MAX
