Pagina 23 di 50 primaprima ... 13212223242533 ... ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #221
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I know
    I sync & compile every day
    What is the problem with the front camera? Can you tell me? Thank you Bother you
    Quote Originariamente inviato da awssong Visualizza il messaggio
    try with this patch
    Gerrit Code Review
    Nubia Z7MAX
  4. #223
    Nov 2015
    try with this patch
    Gerrit Code Review
    Thanks!Paolo
  5. #224
    Nov 2015
    Thanks!Paolo
    I will not use GIT download, I downloaded the tar file directly, and then replace all the files under hardware/qcom/display/msm8974, the problem is there, is not the replacement hardware/qcom/display-caf/msm8974?
  6. #225
    Nov 2015
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/instrumentation_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/indirect_reference_table_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/invoke_type_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/jdwp/jdwp_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/jdwp/jdwp_constants_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/lock_word_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/mirror/class_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/oat_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/object_callbacks_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/profiler_options_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/quick/inline_method_analyser_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/runtime_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/stack_operator_out.cc
    Copy: /home/syai2012/android/aicp/out/target/product/nx505j/obj/SHARED_LIBRARIES/libart_intermediates/thread_operator_out.cc
    Makefile:130: recipe for target 'sub-make' failed
    make[1]: *** [sub-make] Error 2
    make[1]: Leaving directory '/home/syai2012/android/aicp/kernel/nubia/nx505j'
    build/core/tasks/kernel.mk:233: recipe for target 'TARGET_KERNEL_BINARIES' failed
    make: *** [TARGET_KERNEL_BINARIES] Error 2
    make: *** 正在等待未完成的任务....
    #### make failed to build some targets 48m:08s
    I was in the process of compiling, encountered this error, what is the reason?
  7. #226
    Dec 2015
    Angry
    HiPaolo
    There is already some guys in chinese forum using your device code to compile rom with bloatware.
    bbs.nubia.cn/thread-573319-1-2.html
    there is no dfference compared to your cm13 but MORE BUGS AND SEVERAL JUNK APPS.
  8. #227
    Oct 2015
    I updated yesterday, and it worked perfect for a few hours but then it got stuck in a bootloop. Then I reflashed everything and it seems to be fixed so thank you very much paul for this awesome rom!!
  9. #228
    Nov 2015
    Quote Originariamente inviato da nubiaz7max Visualizza il messaggio
    HiPaolo
    Resolutely refused to add third hair or software
  10. #229
    Oct 2015
    hey paul is it possible to use 3g on both simcards?, I only get 3g on sim1 :/
  11. #230
    Jan 2015
    Nubia Z7 Max
    Quote Originariamente inviato da hobo Visualizza il messaggio
    Paolo can't help you with that, it's a hardware limitation of the device. It's only capable of 3g/4g on one sim and 2g on the other.
