Pagina 24 di 50 primaprima ... 14222324252634 ... ultimoultimo
Visualizzazione dei risultati da 231 a 240 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #231
    Oct 2015
    that's weird because on the other rom (Lollipop Nubia Z7 Max mod by pesa1234) you can use both cards for 3g and 4g
    Quote Originariamente inviato da hobo Visualizza il messaggio
    hey paul is it possible to use 3g on both simcards?, I only get 3g on sim1 :/
    you can one sim at a time (hardware limitation)
    just set the sim 1 in gsm only and sim 2 in global
    Nubia Z7MAX
  4. #233
    Oct 2015
    It might be a bug then? I can only choose global on sim1(slot 1), even if I only have sim 2(slot 2)in my phone I can't change it. (only gsm can't choose global on slot2)
  5. #234
    Jun 2015
    Yesterday i make a Backup with Titanium. The Backupfile ia on the SD Card. This is a SanDisk with 64GB Storage. But Titanium says It is not enough memoryspace available. But there is about 30Gb free. What is the issue? And what can i do?
  6. #235
    Oct 2015
    Hello, Paolo. Recently there is a new version released? Beta3 is very good. Looking forward to your reply.If not, we will continue to wait for your new work. Thanks
  7. #236
    Quote Originariamente inviato da flasher Visualizza il messaggio
    for backups it is preferable to use the internal memory
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    beta 4 today or tomorrow at the latest
    Nubia Z7MAX
  8. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (19-12-15),migel121 (19-12-15),narutonote (19-12-15)
  9. #237
    beta4 in first page
    Nubia Z7MAX
  10. I seguenti 6 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (19-12-15),flasher (19-12-15),jadar (20-12-15),mai62 (19-12-15),migel121 (19-12-15),narutonote (21-12-15)
  11. #238
    Jun 2015
    Thanks for Rom. Now i have H+ with German Vodafone.
  12. #239
    Oct 2015
    Hi, Paolo. Recently Nubia official forum appeared a lot of self compiled ROM CM13.
    They are all more or less a problem. Some ROMer even built third party junk software to profit. Use your source, but no thanks.
    We strongly resisted these ROMer. CM series of ROM, we still trust Paolo's work We will always support you.
    Thanks.
  13. Il seguente Utente ha ringraziato narutonote per il post:
    flasher (25-12-15)
  14. #240
    Oct 2015
    Merry X‘mas!
    Ultima modifica di narutonote; 25-12-15 alle 01:44
  15. I seguenti 2 Utenti hanno ringraziato narutonote per il post:
    jadar (25-12-15),migel121 (25-12-15)
