Pagina 25 di 50 primaprima ... 15232425262735 ... ultimoultimo
Visualizzazione dei risultati da 241 a 250 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #241
    Sep 2015
    Joyeux Noël !
    Feb 2014
    Frohe Weihnachten, Merry Christmas.
  4. I seguenti 2 Utenti hanno ringraziato migel121 per il post:
    flasher (25-12-15),jadar (25-12-15)
  5. #243
    Merry Christmas !!
    Nubia Z7MAX
  6. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    jadar (25-12-15),mai62 (25-12-15),migel121 (25-12-15),narutonote (25-12-15)
  7. #244
    Oct 2013
    Merry Christmas !!!!
  8. #245
    Dec 2015
    Hi Paolo!
    I try to use CM13 beta 4 and found some bugs
    1. When answer the call the caller cannot hear me immediately. After a few seconds is possible to talk. Perhaps this is the reason too that the sound of the end of the talk a few seconds late.
    2. Do not work correctly DTMF. When dialing also has a timeout, dial the three-digit tone is not possible.
    3. The sound (not talk) on Bluetooth headset hear delayed and interruptions. If to answer in the headset, the sound first appears on phone earpiece.
  9. #246
    Oct 2015
    Hello, Paolo. I used Beta4 for a while and found a few bug.
    1. When opening double click on the bright screen. Mobile phone lock, the phone will automatically light up the screen, but can not be answered, must be locked after the unlock to slide. The problem is only occasionally.
    2. During the call if the phone left the face, the screen will not be lit, you must manually lock the unlock to light. This is also an incident, the distance sensor is a little problem.
    3. On the dual card problem. If the card 1 uses the mobile data network, the card 2 sends the short message by default, after the mobile phone restart the mobile data network will become the card 2. Even if you choose to send text messages each time asked, the mobile data network will change, unless the default send text messages to send SIM card.
    Compared to the first two questions, the third problems significantly affect the small point. After all, the resumption of the situation is relatively small.
    Do not know if you have encountered the same problem? Looking forward to your reply. Thanks.
    Ultima modifica di narutonote; 27-12-15 alle 02:28
  10. #247
    beta5 link in first page
    Nubia Z7MAX
  11. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    jadar (28-12-15),mai62 (28-12-15),narutonote (28-12-15)
  12. #248
    Dec 2015
    On the CDMA network,“Received calls” is display“unknown” 。
  13. #249
    Oct 2015
    Hello, Paolo. I used the just released Beta5 and found a bug.
    When you load the two SIM cards, card 2 can switch the network, but the card 1 can not switch network type. Always show the global, network locked in 2G. Only a SIM card, then there is no problem.
    I performed a clean installation, but the problem still exists.
    I hope you can release a patch, thank you very much
  14. #250
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    umh I saw
    you can switch the network preferred type only on the sim with the data connection enabled
    so if you have the connection data on sim 2 you can't change the preferred network on sim 1 (and vice versa)
    Nubia Z7MAX
