Pagina 17 di 50 primaprima ... 7151617181927 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #161
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    you mean the data connection ?
    is normal
    No, i mean disconnected during a phone call
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Paolo, is it possible to make a split-screen as on the factory firmware? A handy feature that is missing.
    4PDA community from Russia
  4. #163
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    you can enable the multi-window feature in developer options
    https://www.youtube.com/watch?v=VAShEv3_rKI
    Nubia Z7MAX
  5. #164
    Nov 2015
    is normal
    Why do you compile the version of the API level that is 4? Here https://source.android.com/source/bu...ags-and-builds, API level has reached 23?
    What are you in the MEGA cloud space?
  6. #165
    Quote Originariamente inviato da awssong Visualizza il messaggio
    API 4 ? what are you talking about ?
    marshmallow is API 23
    sorry but I do not understand the question
    Nubia Z7MAX
  7. #166
    Nov 2015
    Your new version for a long time? I have finished cm_strings.xml according to CM12.1, do you have to help me give you?.
    http://yunpan.cn/c3jHFh4PRbAxz (提取码:f176)
    I see you have a few patches in the MEGA cloud, cm13_dotcase_fixswipe_v2.zip is the use of? API CyanogenMod level is (4)
  8. #167
    ?????? - 360?? (提取码:f176)
    the translation of the rom will be made at a later stage
    yes, I have fixed a bug with the dotcase (the swipe for answer/cancel a call did not work)
    ah ok, cyanogen api is 4 but it's a different thing than android api
    Nubia Z7MAX
  9. #168
    Nov 2015
    OK, thank you Paolo, look forward to your work, thank you very much for your hard work!
  10. #169
    Nov 2015
    Is the new version encountered a problem? What time is your BETA2?
  11. #170
    no no problem, I just waiting some days for the december security patch
    Nubia Z7MAX
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
    flasher (03-12-15)
