Pagina 27 di 50 primaprima ... 17252627282937 ... ultimoultimo
Visualizzazione dei risultati da 261 a 270 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #261
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Quote Originariamente inviato da momomo Visualizza il messaggio
    everything works pretty well but when using bluetooth earphone sometimes the sound is interrupted. .And sometimes the wifi is unavailable after soft reboot(not a serious problem).
    Hi Paolo. Same problem here with Bluetooth. More data:
    - I have experienced this problem with both beta5 and beta6 and Radio 3.70. I don't know if with previous beta version since last time I used bt link for music I was running CM12.1
    - This only happens with music. Not with handsfree device.
    - I have tested with three different devices: logitech, amp and a chinese "enjoy" device. All with the same problem.
    - Tested from Spotify and YouTube apps.
    When listening music songs are choppy. Link is established but its impossible to hear a constant song for more than a second.
    I will test with previous basebands.
  2. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (07-01-16)
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Confirmed. It is a baseband issue. With 3.60 no problem
    I will check all until find newer one without this issue!!
  5. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (07-01-16)
  6. #263
    Jan 2015
    Nubia Z7 Max
    So, is there a database of baseband zips anywhere? I'm searching and can't really find any. Does anyone have 3.60 or 3.62? They're the newest ones that appear to be stable.
  7. #264
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da RoboTrigger Visualizza il messaggio
    Look at first post. In baseband link, Paolo has a full recopilation at Mega.
    I can confirm that 3.65 also works. I will test this afternoon 3.68 and 3.69 to find where ZTE broke Bluetooth. ;-)
  8. #265
    May 2015
    Madrid, Spain
    Nubia z7 max
    Hi everybody.
    Regarding Bluetooth audio problem, definitively it's a Baseband bug.
    Baseband from 3.60 to 3.67 do NOT have any problem with Bluetooth audio.
    Baseband from 3.68 to 3.70 do HAVE this problem.
    So, if Bluetooth audio is a must for you (for example in my case) do not use Baseband newer than 3.67.
    Hope ZTE solve this issue in next Baseband releases.
    Paolo, perhaps could be a good idea warn about this at first post. Feel free to transfer this knowledge to Italian forum, of course. ;-)
  9. I seguenti 4 Utenti hanno ringraziato inigoml per il post:
    flasher (05-01-16),narutonote (08-01-16),PaoloW8 (07-01-16),xyxy (07-01-16)
  10. #266
    Jan 2015
    Nubia Z7 Max
    I knew it was somewhere but I guess I'm going either old or blind. Thanks
  11. #267
    Oct 2015
    Hello, Paolo, beta6 seems to be a problem After the restart,the 4G network will become the 2G network, you need to manually change the manual into the network priority options.
  12. #268
    May 2015
    Madrid, Spain
    Nubia z7 max
    Hi everybody.
    More info:
    - I was able to reproduce this issue with baseband 3.67 and 3.62. After several minutes working well audio output started choppy again.
    - Same behaviour that in 3.68 and later baseband.
    I think this is not only baseband related. There must be something else at ROM level, I'm afraid...
  13. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (07-01-16)
  14. #269
    @inigoml thanks for the report and tests
    I have reported your conclusions in the Italian forum here
    for those looking for the baseband zip: all baseband zip
    Ultima modifica di PaoloW8; 07-01-16 alle 11:16
    Nubia Z7MAX
  15. #270
    maybe I fixed the problem (kernel related)
    now I have the baseband 3.70 and bluetooth seems to work well
    I do more testing
    Nubia Z7MAX
  16. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    inigoml (07-01-16),jadar (07-01-16),narutonote (08-01-16)
