Pagina 18 di 50 primaprima ... 8161718192028 ... ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #171
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    no no problem, I just waiting some days for the december security patch
    About when to come out a new security patch?
    Quote Originariamente inviato da awssong Visualizza il messaggio
    I really don't know
    I wait a few days and then I will make the beta 2 (even without the security patch)
    Nubia Z7MAX
  4. #173
    Nov 2015
    I really don't know
    Thanks!Paolo!
  5. #174
    Nov 2015
    I really don't know
    Want to get your beta2 adapter code upload. Thank you! Thank you for your patience.
  6. #175
    Nov 2015
    Your beta2 for a long time? Broad net friend
  7. #176
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    After formatting the SD-card in Android 6.0 and return it to a state of "portable" it ceased to be read in TWRP. If you select SD-card recovery TWRP freezes.
    TWRP sees space on the sd-card, but when choosing a card in the section Restore permanently hangs. Mount does not work from a recovery.
    I tried to format the card to FAT32 and extFAT on the PC. Did not help.
    SD-Card is readable on a computer and in the CM12, but TWRP freezes and I can not make a backup or recover from it.
    Another SD card works in TWRP without problems. Her I have not formatted in Android 6.0. So the problem is in the SD-card.
    User brooklyn2006 same problem. He said on this forum 4PDA.
    Ultima modifica di LiveMoto; 06-12-15 alle 10:30
    4PDA community from Russia
  8. #177
    Nov 2015
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    I also have the same problem, before several versions will not appear.
  9. #178
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    I fixed it with the help of the program Transcend Autoformat v1.8 (SD, MMC, CF) / FlashBoot.ru
  10. #179
    Jun 2015
    Hello, i have a question. Have i the possibility to disable this message:
  11. #180
    Jun 2015
    Or how can i switch from manuel to automatic Network search?
