Pagina 19 di 50 primaprima ... 9171819202129 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #181
    I'm compiling right now
    Nubia Z7MAX
    Quote Originariamente inviato da awssong Visualizza il messaggio
    About how long it will be released? I only need 1 hours and 10 minutes to compile CM13.
    stop ask the same thing again and again and again ....
    when is ready I will upload
    Nubia Z7MAX
  4. #183
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Exclamation
    Enough to stick with similar problems to the developer. Be patient. People without IT-education is very difficult to understand the specifics of working in this field. When compiling the final result is something can go wrong and you have to understand the problem again and again.
    His message you only brake developer.
    Want it went faster then stimulate his work. Throw a couple of euro to the account PayPal Paolo and say thank you.
    4PDA community from Russia
  5. Il seguente Utente ha ringraziato LiveMoto per il post:
    PaoloW8 (08-12-15)
  6. #184
    beta 2 and changelog in first page
    Nubia Z7MAX
  7. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    jadar (08-12-15),LiveMoto (09-12-15),tigreos (08-12-15)
  8. #185
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    You are the best, Paolo.
    By the way...what will be your next phone? We are here organizing in Madrid a fan group and we will buy the same phone you have in the future! :-D
  9. #186
    Sep 2015
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    I totally agree with you. I'd be glad to be part of the french chapter of the fan club 😁
  10. #187
    ahaha lol
    btw, for the moment I have no plans to change phone
    Nubia Z7MAX
  11. #188
    Aug 2015
    hi!paolothlw8.
    your cm13 is pretty good.but when i enable navigation bar,the softkey is not disabled.could you plz fix it and make a patch?
  12. #189
    Quote Originariamente inviato da momomo Visualizza il messaggio
    hi!paolothlw8.
    yes I know
    I have to find a different way to disable it (as I did in cm12.1 not work in the CM13)
    Nubia Z7MAX
  13. #190
    hi!paolothlw8.
    yes I know
    ok done
    flash this zip without any wipe
    cm13.0fix_DisableSoftkeyWithNavbarEnabled.zip
    when enable/disable the navbar the softkey are disabled/enabled after a reboot
    Nubia Z7MAX
