Pagina 28 di 50 primaprima ... 18262728293038 ... ultimoultimo
Visualizzazione dei risultati da 271 a 280 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #271
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Fantastic! ;-)
    Aug 2015
    hi paolo!there is a little problem. In preferred network type, when choosing td-scdma/gsm/lte, it would change into gsm/wcdma/lte(some other seletion seems to have the same problem), and as a result i can not use 3g(td-scdma), could you please try to fix it?
  4. #273
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    maybe I fixed the problem (kernel related)
    now I have the baseband 3.70 and bluetooth seems to work well
    I do more testing
    Paolo, if you need further testing, count with me. Since I usually take a shower with spotify connected to a bluetooth speaker, I can test it intensively. ;-)
  5. #274
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    I tried several times with a bluetooth headset and streaming via Bluetooth with the PC and it has always worked well
    I think that the bug is fixed
    probably tomorrow I will release the beta7
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    jadar (08-01-16)
  7. #275
    May 2015
    Madrid, Spain
    Nubia z7 max
    OK. Waiting for next release! Thank you.
    By the way... what do you think about Huawei Mate 8... what a good phone for 2016... you need it (and I need it!!!)
  8. #276
    when I will change phone I will stay on Qualcomm soc (for documentation, community, source code etc)
    Nubia Z7MAX
  9. #277
    May 2015
    Madrid, Spain
    Nubia z7 max
    Then, Mi 5... Nubia Z11.... :-D Anyway, remember to warn us when you decide to replace your Z7max! :-)
  10. Il seguente Utente ha ringraziato inigoml per il post:
    jadar (09-01-16)
  11. #278
    link and changelog beta7 in first page
    sure
    Nubia Z7MAX
  12. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (09-01-16),jadar (09-01-16),migel121 (09-01-16),narutonote (09-01-16)
  13. #279
    May 2015
    Madrid, Spain
    Nubia z7 max
    Bluetooth behaviour now is the same with 3.70 that with 3.67. It works well but after some time problem arises again. I've been playing music for almost two hours without issus but after stopping playing and resuming some minutes later problem with choppy playback started again.
  14. #280
    Feb 2014
    With the beta 7 my MI band combines not with the phone settings in the Bluethoot he finds the band but can not pairing up.
