Pagina 22 di 50 primaprima ... 12202122232432 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #211
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    link beta3 and changelog in first page
    Ask a more mentally retarded question, CM's source code is generally in a day when the update is appropriate? Is it morning or afternoon? Or at night, thank you!
    Jul 2015
    Stock browser crashes when trying to download the file.
  4. #213
    Nov 2015
    You provide the latest ROM the status bar and desktop time not update automatically? Don't know if you have this problem, I am after all wipe brush into the.
  5. #214
    Jun 2015
    Pablo, thanks for your work. The Cm is amazing and my issue from Post 179 is away. The Rom is very smooth. Thanks an i look at the final CM13. Thanks
  6. #215
    Nov 2015
    You provide the WIFI beta3 drop-down menu, click no response, the new CM source code in the synchronization today has been normal use. WIFI connection is relatively stable.
  7. #216
    Oct 2015
    hey I have a few questions:
    1. Can I use xposed on this rom without problems?
    2. Can I update from 5.1.1 directly to this rom?
    3. Are the security isseus (like starfright) fixed
    thanks in advance
  8. #217
    Quote Originariamente inviato da awssong Visualizza il messaggio
    I know
    I sync & compile every day
    Nubia Z7MAX
  9. #218
    Quote Originariamente inviato da hobo Visualizza il messaggio
    thanks in advance
    1) I don't know, I not use xposed...if exist xposed for marshmallow 6.0.1 I think yes
    2) no
    3) sure
    Nubia Z7MAX
  10. #219
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    thanks in advance
    It's important to read first post. I doesn't take a lot of time. If you had read it, questions 2 and 3 would be already responded. Remember starfright bug was solved months ago.
    Xposed framework has issues with Marshmallow. If you read first page at official thread at XDA, it would have also already answered.
    Thank you!
  11. #220
    May 2015
    Madrid, Spain
    Nubia z7 max
    One possible bug and/or unexpected behavior.
    When charging device, screen turns on and off without randomly, between seconds and minutes without receiving any event (message, etc).
    This only happens when charging.
    Anybody has experienced this issue?
