Pagina 26 di 50 primaprima ... 16242526272836 ... ultimoultimo
Visualizzazione dei risultati da 251 a 260 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #251
    Oct 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    umh I saw
    you can switch the network preferred type only on the sim with the data connection enabled
    so if you have the connection data on sim 2 you can't change the preferred network on sim 1 (and vice versa)
    This I understand. I mean card 1 using a data network when the network type is always 2G. Select other types will not change. This situation only occurs when the mobile and China Unicom dual sim. Affected only card 2, card 1 will not be affected.
    Oct 2015
    umh I saw
    I'm trying to return to the official firmware 3.70. The type of network to normal after implementation of clean install CM13, but the problem is still there.
  4. #253
    Oct 2015
    Paolo, I have resolved. I have to test telecommunications, the use of recovery to restore the telecommunications-related baseband file and then return to the Mobile and China Unicom baseband files. Then confusion locking 2G. Unable to switch network type. Now restore telecommunications baseband files in the case of mobile Unicom card and then restore files Mobile and China Unicom now has been able to properly switched network type. Bring you trouble very sorry. Thank you for your reply.
  5. Il seguente Utente ha ringraziato narutonote per il post:
    PaoloW8 (28-12-15)
  6. #254
    Quote Originariamente inviato da narutonote Visualizza il messaggio
    ehehe np
    I'm glad you've solved
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    narutonote (29-12-15)
  8. #255
    Oct 2015
    Good morning, Paolo. I found it was not the way I imagined it. Now I finally understand. Beta5 replaced the communication module, SIM card 1 and SIM card 2 only one SIM card can switch network type.
    If you want to use SIM card 2 of the data network, you must first switch to SIM card 1 into GSM, and then to go to the SIM card 2 switch network priority options. (and vice versa)
    Beta5 only one SIM card can modify the network preference, I think before the direct switch. In fact, or the same as before.
  9. #256
    Dec 2015
    Hi,Paolo. I am China user,I hava a NFC-SIM,this NFC-SIM can be used as a traffic card in China.
    But I can not use this feature on CM,because CM can not choose NFC settings to use SIM security module.I want to use this NFC-SIM to replace my traffic card .
    Can you add this feature ? If SIM1 is NFC-SIM can choose NFC settings ,Built in security module or SIM security module. I hope...
  10. #257
    dve
    dve non è in linea
    Dec 2015
    Hi Paolo, thank you for your work.
    Do you can add fuse in kernel?
  11. #258
    Aug 2015
    everything works pretty well but when using bluetooth earphone sometimes the sound is interrupted. .And sometimes the wifi is unavailable after soft reboot(not a serious problem).
  12. #259
    link beta6 in first page
    Nubia Z7MAX
  13. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    flasher (03-01-16),jadar (03-01-16),mai62 (03-01-16),migel121 (03-01-16)
  14. #260
    Jun 2015
    Hello Paolo, please Look at first page. The new Update is Beta 5? Please change to Beta 6. Thanks.
  15. Il seguente Utente ha ringraziato flasher per il post:
    PaoloW8 (03-01-16)
