Pagina 34 di 50 primaprima ... 24323334353644 ... ultimoultimo
Visualizzazione dei risultati da 331 a 340 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #331
    Jan 2015
    Nubia Z7 Max
    Hi Paolo,
    I have a bug report that I noticed on V3 and V4, and have now figured out what causes it: when I dial a phone number from the dialer, all system sounds (notifications, locking/unlocking, ringtone etc.) become very quiet.
    I believe that it's normal for the Android system to decrease the volume of system sounds during phone calls, but it doesn't seem to reset the sound level back to the regular one after the phone call is done. I can't find any change in system volume settings before and after this occurs.
    The sound volume goes back to normal after performing a soft reboot after the phone call, so it's probably a problem somewhere in userspace and not the kernel.
    I'm going to try and reinstall V2 and see if that happens there too, since CyanogenMod seems to have changed the dialer/contacts and SMS apps between V2 and V3.
    Cheers!
    EDIT: bug is not present on V2.
    EDIT #2: bug is present in V2 but in different form, it's not enough just to call a number and then hang up, you have to actually have a conversation. Soft reboot still fixes it.
    EDIT #3: I'm going to do a fresh reinstall and see what happens since this has gotten weird. Does anyone else have this problem?
    EDIT #4: After spending yesterday testing stuff, turns out it's caused by some weird combination of apps on my part. Sorry for the false alarm
    Ultima modifica di RoboTrigger; 13-03-16 alle 13:59
    Aug 2015
    Hello, I would like to DIY others ROM. I extracted system.new.dat & system.transfer.list. from the ROM. Then I used the tool from XDA forum named "Unpack Repack System.new.dat" make system.new.dat & system.transfer.list to unpack, and then removed some promotional softwares I do not need , has been re-packaged a new system.new.dat & system .transfer.list file, and then put the new files into the original ROM. But it's failed to flashing, I guess because the file named system.patch.dat. Can you teach me how to get new system.patch.dat it ^_^?...
  4. #333
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    CM13 final version just released!!
    Hope it will solve music Bluetooth bug! :-)
  5. #334
    link release V5 in first page
    Nubia Z7MAX
  6. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (24-03-16),inigoml (23-03-16),jadar (23-03-16)
  7. #335
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Thank you, Paolo. Here we go!
  8. #336
    Jul 2015
    On release V5 phone reboots during an incoming call. Thank you, Paolo.
  9. Il seguente Utente ha ringraziato mai62 per il post:
    PaoloW8 (24-03-16)
  10. #337
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    yes, confirmed by other users
    for now stay with the V4, I working for fix this bug
    Nubia Z7MAX
  11. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (24-03-16)
  12. #338
    Sep 2015
    Is it possible to install v4 on v5 (after having wiped dalvik & cache)?
  13. #339
    Jul 2015
    Quote Originariamente inviato da jadar Visualizza il messaggio
    I tried doing a full wipe. Phone restarts anyway.
  14. #340
    maybe yes, I have not tried
    Nubia Z7MAX
