Utente del giorno: hobin con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 6 di 8 primaprima ... 45678 ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 74
SENSE o AOSP(CM; MIUI..)? quale Sceglire?
  1. #51
    Ho messo in download la virtous doubleshot e dal changelog promette bene una sense 3 molto ottimizzata e performante a più tardi per gli aggiornamenti aosp vs sense la lotta continua
    Androidiano L'avatar di prenci
    Nov 2009
    Ringraziato 10 volte in 4 Posts
    non occorre il telefono del tuo amico tanto piu che non è sbloccato
    quindi consuma il doppio
    basta che posti qui dei log sui consumi di 5 ore il resto non serve
    codice:
    2011/07/11 04:25:35,-1mA,20%,3.757V
    2011/07/11 04:35:37,-1mA,20%,3.757V
    2011/07/11 04:39:27,-2mA,20%,3.757V
    2011/07/11 04:50:44,-1mA,20%,3.757V
    2011/07/11 04:50:44,-5mA,20%,3.757V
    2011/07/11 04:55:44,-5mA,20%,3.757V
    2011/07/11 05:05:46,-5mA,20%,3.757V
    2011/07/11 05:09:28,-5mA,20%,3.757V
    2011/07/11 05:14:53,-5mA,20%,3.757V
    2011/07/11 05:19:01,-50mA,19%,3.713V
    2011/07/11 05:19:01,-180mA,19%,3.711V
    2011/07/11 05:25:42,-180mA,19%,3.711V
    2011/07/11 05:25:42,-180mA,19%,3.752V
    2011/07/11 05:29:55,-183mA,19%,3.711V
    2011/07/11 05:31:30,-183mA,19%,3.711V
    2011/07/11 05:31:30,-9mA,19%,3.755V
    2011/07/11 05:33:53,-182mA,19%,3.725V
    2011/07/11 05:39:29,-1mA,19%,3.757V
    2011/07/11 05:39:30,-1mA,19%,3.757V
    2011/07/11 05:49:32,-5mA,19%,3.757V
    2011/07/11 05:55:43,-12mA,19%,3.757V
    2011/07/11 06:05:45,-15mA,19%,3.757V
    2011/07/11 06:09:30,-1mA,19%,3.757V
    2011/07/11 06:19:33,-9mA,19%,3.757V
    2011/07/11 06:25:43,-1mA,19%,3.757V
    2011/07/11 06:28:21,-5mA,19%,3.757V
    2011/07/11 06:38:24,-5mA,19%,3.757V
    2011/07/11 06:40:42,-10mA,19%,3.757V
    2011/07/11 06:40:42,-5mA,19%,3.757V
    2011/07/11 06:50:45,-1mA,19%,3.757V
    2011/07/11 06:55:43,-5mA,19%,3.757V
    2011/07/11 07:05:46,-5mA,19%,3.757V
    2011/07/11 07:09:35,-5mA,19%,3.757V
    2011/07/11 07:15:12,-1mA,19%,3.757V
    2011/07/11 07:19:20,-181mA,18%,3.706V
    2011/07/11 07:25:42,-1mA,18%,3.706V
    2011/07/11 07:29:44,-5mA,18%,3.706V
    2011/07/11 07:34:11,-180mA,18%,3.706V
    2011/07/11 07:39:37,-1mA,18%,3.706V
    2011/07/11 07:49:39,-5mA,18%,3.706V
    2011/07/11 07:55:43,-5mA,18%,3.706V
    2011/07/11 08:05:46,-5mA,18%,3.706V
    2011/07/11 08:09:38,-3mA,18%,3.706V
    2011/07/11 08:20:44,-5mA,18%,3.706V
    2011/07/11 08:25:42,-24mA,18%,3.706V
    2011/07/11 08:31:07,-5mA,18%,3.706V
    2011/07/11 08:39:40,-7mA,18%,3.706V
    2011/07/11 08:44:48,-5mA,18%,3.706V
    2011/07/11 08:44:49,-5mA,18%,3.706V
    in 5 ore e 20 minuti 2%
    ogni tanto c'è un picco di consumo che penso sia per il sync Facebook e Google, però anche così la batteria non ne risente troppo per fortuna.
    Ciao!
  4. #53
    Feb 2011
    Hai flash qualche script uv di lordmod?
    HTC Desire HD
    ROM: RCMix HD KINGDOM v0.1
    RADIO: 12.54.60.25_26.09.04.11_M2
    KERNEL: Stock
    RECOVERY: CWM 3.0.2.6
  5. #54
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da prenci Visualizza il messaggio
    codice:
    il consumo è ottimo anche se le ore non sono 5.20 ma 4.20 e il consumo
    è il 3% ; il test andrebbe fatto a batteria carica ...
    comunque è un dato eccellente per qualunque rom dal momento che rimane sotto l'1% ora
    se si considera il dato pieno leggibile che va dalle 5.19 quando scatta il 19% e le 7.19 quando scatta il 18% il consumo è esattamente 0.5% ora
    meglio non puo andare se confermato dal test con batteria carica...
  6. #55
    Androidiano VIP L'avatar di tammazz
    Jan 2011
    Htc one m8
    Ringraziato 281 volte in 241 Posts
    Che resta non troppo diverso dalla mia Virtuous xD solo che il max sleep oc era ancora ad 806
    Os 6.12.401.4
    Rom Leedroid MM v8. 0.0 r33
    Kernel stock
    S-off
    [GUIDA] flash fw senza pc, cavetti, strane congiunzioni astrali xD
    ONE PLUS ONE
    Rom cm 13 jgcaap
  7. #56
    Dec 2009
    Rimini
    Quote Originariamente inviato da tammazz Visualizza il messaggio
    diciamo che per molte sense rappresenterebbe la norma
    ma per le AOSP è una vera conquista che dimostra che ormai
    ce la si gioca ad armi pari anche sui consumi....
  8. #57
    Feb 2011
    La norma fare 0,5% l'ora??
    La norma era 1% l'ora... mi sembra che neanche mem che ha i consumi migliori al mondo tra i possesso del desire hd abbia mai postato un log da 0,5% l'ora netti (con le sense)... come confermano anche i suoi post nel 3d della hydorgen questa aosp supera (e non di poco) le sense per quanto riguarda la durata della batteria... poi per il resto non so...(anche se secondo me il kernel fa la sua parte non solo la rom)
    Ultima modifica di Nash16; 11-07-11 alle 17:24
    HTC Desire HD
    KERNEL: Stock
  9. #58
    Banned
    Jan 2011
    Quote Originariamente inviato da Nash16 Visualizza il messaggio
    Ok..ma il discorso di linux era una proporzione..a parità di processi attivi, la dense va tranquilla ma la aosp non si muoverebbe..quindi anche se la aosp consuma meno, è solo perché ha meno processi attivi e non potrebbe essere in grado di attivarne altri..ergo, le sense consumano di meno e sono più performanti..e ha ragione ragazzi..da vendere;-) all'atto pratico ovviamente consuma meno un aosp ma solo in apparenza e in condizioni di disuguaglianza rispetto alla sense..
    Inviato dal mio Desire HD usando Tapatalk
  10. #59
    Feb 2011
    Si ma se avere più processi attivi non porta vantaggi sensibili la sense sarà anche più "bella" perché ha tanti processi attivi e consuma poco ma la cosa è in verità abbastanza inutile...almeno per la maggior parte dell'utenza.. il discorso dei processi ha senso finché la rom riesce ad eguagliare la durata della batteria delle aosp. Se è così la maggior parte degli utenti può scegliere a parità di batteria di optare per la rom che gestisce più processi anche se torno a ripetere che a mio parere pochi si accorgono di questo dato. Altrimenti nel momento in cui la.sense deve sacrificare la durata della batteria (che è in realtà il vero dato che muove il mercato e la scelta del singolo) o si migliora la rom o le fai gestire meno processi. Se no è ovvio che la gente inizia a preferire le aosp...
    Ultima modifica di Nash16; 11-07-11 alle 19:31
    HTC Desire HD
    KERNEL: Stock
  11. #60
    Androidiano VIP L'avatar di Senso41
    Apr 2011
    XIAOMI MI A2 4/64
    Ringraziato 2,334 volte in 1,670 Posts
    Anche l'occhio vuole la sua parte, altrimenti tante cose scritte in questi forum non avrebbero senso. Ci sono sempre i compromessi tra performance ed estetica.
    Gli effetti della sense 3 ragazzi vengono da un altro pianeta anche se la batteria dovesse durare un'ora in meno a mio parere.
    DHD+Rom Virtuous 1.27+Kernel stock+Tapatalk
    Xiaomi Mi A2
