Pagina 182 di 301 primaprima ... 82132172180181182183184192232282 ... ultimoultimo
Visualizzazione dei risultati da 1,811 a 1,820 su 3003
[MODDING] LeTV X500 TWRP + Firmware powered by BB72
  1. #1811
    Androidiano L'avatar di TiD91
    Dec 2015
    Ringraziato 83 volte in 63 Posts
    Quote Originariamente inviato da laikexpert Visualizza il messaggio
    How to install LeTV x507 EUI 5.5.008S (Indian Stock ROM) on LeTV x500
    1. Download the stock stable firmware from here : http://g3.letv.cn/194/4/13/letv-hdtv...=5&splatid=500
    2. After downloading the "S1_x500-OS-OP-DHXOSOP5500802191S-5.5.008S.zip" file, extract it to a folder on the PC.
    3. Go to <Folder Name you gave>\META-INF\com\google\android
    4. Open the updater-script file with Notepad(Notepad ++ preferable)
    5. Rename all places where you find "X3_HK' TO "X3" ONLY.(DO NOT EDIT ANYTHING ELSE,JUST REMOVE THE "_HK")
    6. Save the file.
    7. Now again make a "zip" of all files you previously extracted. you can give any name to the zip file.(Including the META-INF folder you edited)
    8. Paste this zip to ROOT of your internal storage.
    9. Boot into TWRP Recovery, install this ZIP, And Voila!! It gets SUCCESSFULLY installed.
    Pre-requisites
    1. Phone should have TWRP Recovery installed.
    Original link:
    Help - Official LeEco Le 1s Indian Stock ROM and updates | Page 8 | LeMe Community
    Author: ChandanSwarup
    Any better features on that Rom?
    Androidiano VIP L'avatar di umberto1978
    Sicilia
    Nexus 4
    Ringraziato 1,981 volte in 737 Posts
    No chinese bloatware and launcher without live button (only four icons, like miui or some other...)
    But no multilanguage.
    Inviato dal mio Letv X500 usando Androidiani App
    codice:
    These mist covered mountains, are a home now for me
    But my home is the lowlands, and always will be
    Some day you'll return to your valleys and your farms
    And you'll no longer burn to be brothers in arm
  4. I seguenti 2 Utenti hanno ringraziato umberto1978 per il post:
    DanieleGS (29-02-16),TiD91 (29-02-16)
  5. #1813
    Jan 2016
    buonasera ragazzi,
    ho appena scaricato e installato la nuova rom del mitico bb72 :-)
    e contestualmente fatto il passaggio da wind a tre (testando una scheda al negozio sembra cis ia copertura)
    ho letto che la tre è un pò truffaldina e ha degli addebiti strani e qui su questo forum consiglia adaway che è già presente nella room,
    se lo utilizzo posso avere problemi al telefono?? richiede i permessi di root e ho un pò paura di far danni
    potete aiutarmi e dissipare il mio dubbio?
    grazie di cuore
    ps. il mio le tvx500 è l'invidia di tutti i miei amici
  6. I seguenti 2 Utenti hanno ringraziato Perlamela per il post:
    BB72 (29-02-16),DanieleGS (29-02-16)
  7. #1814
    Androidiano VIP L'avatar di DanieleGS
    Mar 2015
    SHENZEN
    Xiaomi Mi Note 3 Black 6/128
    Ringraziato 1,981 volte in 1,060 Posts
    Quote Originariamente inviato da Perlamela Visualizza il messaggio
    buonasera ragazzi,
    grazie di cuore
    chiama il 133 e parla con un operatore imponendogli di farti bloccare TUTTI i servizi a pagamento......
  8. Il seguente Utente ha ringraziato DanieleGS per il post:
    BB72 (29-02-16)
  9. #1815
    Apr 2015
    Innanzitutto innumerevoli ringraziamenti al mitico BB72, per merito del quale ho acquistato questo meraviglioso terminale arrivatomi da GA direttamente con la DBXCNOP5501001303S.
    Vorrei chiedere tre cose, se possibile:
    - avendolo gia' preso con la ROM installata, per fare l'installazione delle "fix" (ho visto che non funge il tap in alto a dx) devo fare tutti i passaggi che hai indicato in prefazione?
    - wifi non va per niente bene, non mi pare che ci siano fix... devo scaricare qualche app che mi permetta di fixarlo?
    - permessi di root (scusate l'ignoranza) ma come si attivano?
    Ho provato a leggere quasi tutti il trhead e ho fatto anche delle ricerche ma non ho trovato specifiche risposte a questi quesiti.
    Grazie anticipato.
    PS: una curiosita': non ho trovato un widget per la "chiamata diretta" e, questa la cosa piu' strana, non ce l'ho nemmeno in Nova, di cui ho la versione acquistata Prime! SAi nulla?
  10. #1816
    Quote Originariamente inviato da gpjob Visualizza il messaggio
    Grazie anticipato.
    Ciao... Circa il tap per lo sleep nella rom GS non c'è perché a molti non piace (non ho mai capito perché)...puoi installare da recovery il fix relativo...ovvero quello con statusbar stock e sleep.
    Per il WiFi io non ho alcun problema...hai provato con altri router di altri WiFi?... Se hai un router dual band (2.4 e 5 Ghz) se puoi imposta solo 2.4
  11. #1817
    Apr 2015
    grazie mille, per il root?
  12. #1818
    Ciao ragazzi ho un problema con questo terminale
    Ogni tanto si ferma questo processo
    É molto fastidioso in quanto ogni volta che succede WhatsApp inizia a funzionare male,e ogni volta che invio un messaggio esce dall'applicazione dicendo che "WhatsApp has stopped"
    Soluzioni? Per ora l'unica che ho trovato é riavviare il telefono ma capite che non é molto comodo
  13. #1819
    Quote Originariamente inviato da aaaaaasd Visualizza il messaggio
    Hai disabilitato qualche processo?
  14. #1820
    Boh uso greenify ma non ho ibernato nessuna app di sistema
