Visualizza i risultati del sondaggio: CM7 vs MIUI
Chi ha votato
191. Non puoi votare questo sondaggio
  • CM7
    165 86.39%
  • MIUI
    26 13.61%
Pagina 111 di 358 primaprima ... 1161101109110111112113121161211 ... ultimoultimo
Visualizzazione dei risultati da 1,101 a 1,110 su 3573
[ROM] Cyanogenmod 7 [Storico]
  1. #1101
    Jan 2011
    Ringraziato 28 volte in 23 Posts
    Ecco il Changelog della pro Nightly:
    to be included in next nightly:
    The call_ring.absent property is a device specific workaround which should be off by default. (android_frameworks_base)Transform touch coordinates to preview coordinates prior to using them to send touch-focus requests to the driver. (android_packages_apps_Camera)Check supported parameters instead of camera lib manufacturer. (android_packages_apps_Camera)implement 1% battery on select devices (android_frameworks_base)Add Virgin Mobile US to apns-conf.xml. (android_vendor_cyanogen)German: fix strings for custom app icon slider (android_packages_apps_CMParts)extends volume button zoom to video mode * code simplified * key up sound prevented (android_packages_apps_Camera)FM: Improve lock screen behaviour (android_packages_apps_FM)FM: Expose method to close FM device file descriptor (android_frameworks_base)Return to message list if the last message on thread is being deleted (android_packages_apps_Mms)Added new german translation (android_packages_apps_CMParts)Improve legacy tethering code (android_frameworks_base)allow wireless-tools if wpa supplicant is not WEXT with a new flag (android_external_wireless-tools)Do headset filter in center+side audio space (android_frameworks_base)Encore: update fingerprint (android_vendor_cyanogen)legend: Refresh CMParts overlay (android_vendor_cyanogen)Fix missed call notification. (android_packages_apps_Phone)Italian: fix missing string (android_packages_apps_Mms)Gallery3D: allow to enable/disable button-backlight override via overlay (android_packages_apps_Gallery3D)Update 0% battery icon for LDPI devices. (android_vendor_cyanogen)Update Russian translation. Screenshot (android_frameworks_base)Update Russian translation. CMParts (android_packages_apps_CMParts)Update Russian translation. Settings (android_packages_apps_Settings)Updated italian strings for custom app icon on lockscreens (android_packages_apps_CMParts)Support use of target-provided mediaserver. (android_frameworks_base)settings: Updated Italian translations (android_packages_apps_Settings)Revert "Revert "modify the device to enable to get the state as slide-open/slide-close."" (android_frameworks_base)New option "Haptic Feedback" in the notificatin power widget is registered and implemented: The option controls whether the phone vibrates or not when the sound profiles are changed when using the SoundButton of the power widget. Options: (android_packages_apps_CMParts)New option "Haptic Feedback" in the notificatin power widget is registered and implemented: The option controls whether the phone vibrates or not when the sound profiles are changed when using the SoundButton of the power widget. Options: - On - Off (android_frameworks_base)dont add vendor tools to PATH (android_vendor_cyanogen)
    Terminale: iPhone 5
    SO: iOS 7.0.2
    Terminale: Galaxy S3
    SO: ProBam 4.3
    Terminale: Galaxy Next S5570
    SO: CM10.1
    Androidiano L'avatar di Nekos
    Ringraziato 68 volte in 57 Posts
    è da stamattina che aspetto per aggiornare, e ancora continuano ad aggiungere cose, bene bene
  4. #1103
    AlexForTomorrow
    Quote Originariamente inviato da thejacksbad Visualizza il messaggio
    @alex potresti mettere in prima pagina anche il link al kernel fugumood? Grazie
    aggiunto
    personalmente, lo sconsiglio.
    non mi ha mai dato buone performance..
    viva il kernel stock
  5. #1104
    Senior Droid L'avatar di kaisernose
    Apr 2010
    Paternò (CT)
    tanti...ora OneX
    Ringraziato 118 volte in 83 Posts
    Alex tu sei nel giro cyano : 1) quel changelog immenso a chi appartiene?alla #52?
    2) come kernel quale consigli in rapporto al consumo di batteria?o sono tutti una cosa tipo 19 soldi con 1 lira?
    "Beh, perché lo trovava un gran divertimento; perché certi uomini non cercano qualcosa di logico come i soldi: non si possono comprare né dominare, non ci si ragiona né ci si tratta. Certi uomini vogliono solo veder bruciare il mondo."
    G1,Magic,Milestone,NexusOne,GalaxyS,Nexus S,Atrix,Galaxy Nexu,Note e ora HTC ONE X--->Solo perchè ce l'ha Cesco.
    Tab-TF101---NOW Nexus7.
  6. #1105
    Apr 2010
    Paternò (CT)
    tanti...ora OneX
    Quote Originariamente inviato da borjus86 Visualizza il messaggio
    allora io chiedo si il t9 nel dialer..ma nn in stile miui...se volete stile miui,scaricatevi Go contact..che è praticamente identico, e cura anche i contatti..
    ma io nn parlavo di stile,parlavo di funzioni..mi andrebbe bene anche come quello della Sense,Samsung etc etc..qualunque basta che ci sia un t9 nel dialer...certo il tutto si risolve con i vari Gocontact,DialerOne o affini ma sarebbe un ottima aggiunta per le cyano e parlo dal punto di vista di usabilità;in macchina ogni volta devo fare i salti mortali per chiamare qualcuno..invece con t9 faccio prima e con molta più facilità...
  7. #1106
    AlexForTomorrow
    Quote Originariamente inviato da kaisernose Visualizza il messaggio
    si è della 52. ma non fixa chissà cosa.
    se però hanno levato qualche codice di debug, migliorerà un po' la batteria. forse..
    dopo vari test e prove, posso assicurarvi che il kernel migliore è quello stock.
    fine.
    d'altronde (rom instabile + kernel instabile) = instabilità^2
  8. Il seguente Utente ha ringraziato AlexForTomorrow per il post:
    kaisernose (09-07-11)
  9. #1107
    Apr 2010
    Paternò (CT)
    tanti...ora OneX
    Quote Originariamente inviato da AlexForTomorrow Visualizza il messaggio
    il discorso fila cmq vabbè allora nn smanetto sui kernel..lo chiedevo per avere una falsa speranza di poter migliorare la batteria cmq vorrà dire che mi tengo sto Wolverine #1..
  10. #1108
    AlexForTomorrow
    eh si...
    alla fine il massimo che puoi fare è mettere un governor conservative
    (da cyanogenmod>performance>CPU)
    e giocherellare con l'UV con voltagecontrol.
    ma niente di più
  11. #1109
    Io sto usando il .kernel platypus neo10 da una settimana e mi ci trovo benissimo, cel stabilissimo, durata della batteria come con il stock ma con oc a 1.3 , ma ancora piu fluido e veloce .
  12. #1110
    Apr 2010
    Paternò (CT)
    tanti...ora OneX
    Quote Originariamente inviato da dobion Visualizza il messaggio
    ma il platypus neo10 nn era per le MIUI?!?lo posso flashare pure sulle cyano?
