Pagina 76 di 233 primaprima ... 2666747576777886126176 ... ultimoultimo
Visualizzazione dei risultati da 751 a 760 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #751
    Sep 2010
    Nessuno ha provato la Omni?
    Ci sono state novitā con il rilascio di sorgenti per il Mali (visto l'ultimo update)?
    Senior Droid L'avatar di idiversss
    Nov 2010
    Localitā
    Firenze
    Ringraziato 36 volte in 34 Posts
    Ma le gaps vanno riflashate per forza?
    GALAXY S
  4. #753
    Androidiano L'avatar di Il Burocrate
    Jul 2010
    Nexus 5
    Ringraziato 59 volte in 43 Posts
    PIE č ancora assente?
    Nexus 5
  5. #754
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    Stamani grandissimi aggiornamenti:
    ROM V.5 + nuove Gapps del 18 novembre + nuovo Kernel Temasek con MALI driver
    flashato tutto previo un wipe cache senza nessun problema. Vediamo oggi come si comporta
    Build V5
    md5sum: c9e6c2e5b2f853a95994b02ad48d7db7
    *** IMPORTANT ***
    • I'm posting this changelog before uploading V5. This is to PRE-WARN all users using custom kernels.
    • From V5 onwards, it is using update12 r3p2 mail. It is no longer compatible with custom kernels for cm11 not supporting r3p2 mail.
    • Before you flash any custom kernels over V5 build onwards, pls check with your custom kernel dev if it is ok
    • Temasek cm11 kernel updated to support r3p2 mali in V5. Pls ensure the filename has "r3p2" tag in it before you use. I will now support Wolfson & Boeffla (Both NOABB). Follow stock cm kernel's SELinux as permissive.
    CHANGELOG FOR V5
    • smdk4412-common: update Mali blobs to r3p2 - xploldwild (Omni)
    • CM Stock Kernel in V5 - In sync with Omni android 4.4 branch with r3p2 mali
    • CM Stock Kernel in V5 - Change SELinux to permissive mode
    • Updated - QuickSettings : Port from cm-10.2 (Patchset 16)
    • Updated - QuickSettings: Update all QS drawables to fit KitKat
    • Added "Lockscreen - Customizable shortcuts" - cm
    • Advanced Power Menu - SlimROM
    • fb: use for Global Menu our SlimActions - SlimROM
    • fb: Slims new Power Menu - SlimROM
      - gmillz already prepared it and I finished it now. Idea was to be more flexible on the power menu but at the same time not complicated. So we adapted Power Menu to our dslv system which allows to sort drag swipe etc the entries.
      So user can now have the power menu how they like it. As well custom apps or activities can be added
      So currently:
      airplanemode
      custom apps
      screenshot
      reboot
      sound
      power off
      are available as options to add or remove or customize with our
      easy dslv settings
      - As well we are only using our central classes for it....means adding
      whatever shortcut is mostly only a 10 line change in future
    • fb: color system icons on navring like the other by default - SlimROM
      - otherwise it does not fit with the default rin targets
    • fb: support new dslv
      - see Settings
    • Settings: new dslv + Dialog handling - SlimROM
      dslv get some tweeks to be perfect
      - dialogs get instance handling
      - icons show all in same size independent which icons they are
      - option "none" is on normal action not available and gets filtered
      Other settings:
      - clean up a bit
      - use more centralized strings
      - dialog get instance handling
      - add missing landscape layout settings for color picker
    • Settings - correct navbar landscape default value for reset - SlimROM
    • Updated cm source
    DOWNLOAD SITES
    temasek.hopto.org
    Dev-Host
    AndroidFileHost
    MediaFire
    Ciao scusami ma per ki ha hiā installato cyanogenmod 11 deve riinstallarlo o c'č un modo per fare gli aggiornamenti automaticamente?
  6. #755
    Androidiano VIP L'avatar di Enr1988
    Legend-DS-GS2-GS3-MotoG-Lg G2
    Ringraziato 989 volte in 743 Posts
    Quote Originariamente inviato da Kele Visualizza il messaggio
    La test build della Omni oltre ad avere i nuovi driver mali, integra i sorgenti rilasciati 2/3 giorni fa dalla Userland ( o qlcs del genere) relative a tutto quello che riguarda la parte grafica della nostro s3, dalla foto/videocamera ad un hwcomposer finalmente funzionante e non "riarrangiato"...il tutto prossimamente potrebbe coincidere con il rilascio di build con tutto funzionante..compreso il tvOut, mai funzionante nelle aosp dei terminali Exynos
    Se ti ho aiutato usa il tasto THANKS per ringraziarmi!!
    [B]Oneplus 3/B] Oxygen Os Beta 19 Dorimanx Kernel
  7. Il seguente Utente ha ringraziato Enr1988 per il post:
    Il Burocrate (20-11-13)
  8. #756
    Sep 2010
    Quote Originariamente inviato da Enr1988 Visualizza il messaggio
    quindi č consigliabile rispetto a questa?
    Dove trovi info cosi dettagliate? su XDA?
  9. #757
    Xda, consigliabile al momento? Secondo me no, meglio aspettare che il tutto si "almalgami" per bene, visto che č cambiata tutta la parte relativa alla gestione della Grafica, nella test build attuale della Omni ci sono degli sfalsamenti nei colori di foto/video a meno di non utilizzare un rendering SW nel player...ecc..ma di buono c'č come detto l'Hwcomposer finalmente funzionante..fluiditā in animazioni e rendering 2d/3d incredibile....
    Se tutto va come si spera, anche Temasek integrerā il codice suddetto nella sua Cm11...giā nella V5 ha finalmente messo i nuovi driver mali usciti col update 12 di Samsung..
    Se fino a ieri il mio desiderio di Nexus 5 era quasi implacabile...adesso sto riflettendo sul fatto di tenere l's3 per un altro annetto per fare un vero e proprio salto generazionale a fine 2014.... Fine OT
  10. I seguenti 2 Utenti hanno ringraziato Enr1988 per il post:
    crazyniko (20-11-13),Kele (20-11-13)
  11. #758
    Sep 2010
    come non quotarti. Gli ultimi sviluppi hanno abbassato notevolmente anche in me la fame da N5
  12. #759
    Senior Droid L'avatar di luigiv97
    Ringraziato 48 volte in 40 Posts
    A me il play store mi da errore di connessione
  13. #760
    Androidiano VIP L'avatar di Volpe92
    Localitā
    Venezia
    S3, S6 edge 64gb, note 3
    Ringraziato 172 volte in 139 Posts
    Quote Originariamente inviato da luigiv97 Visualizza il messaggio
    Fai un installazione pulita, wipe data ecc...
    Comunque non vedo l ora di provare le prime build con h w composer
