Magari stasera lo provo, ma se non si integra nella statusbar è inutile come gli altri
Voi che Browser usate? Quello stock o chrome?
Personalmente mi trovo meglio con chrome però sembra come se non fosse bene ottimizzato per il telefono... voi cosa dite?
Edit:
Altra domanda... io uso rete vodafone e sinceramente dove ci sta rete va benissimo...però quando vado in posti dove switcha il 3G al 2G avvolte scompare il segnale o rimane "in stallo" per qualche minuto... è normale?
Ultima modifica di GreatNormalMan; 17-12-13 alle 12:18
Dovresti controllare di avere l'ultimo aggiornamento installato, che oramai per tutte le versioni europee dovrebbe essere la MJ7 (versione build).
Cmq non sei il solo :
Some Galaxy Note 3 units experiencing boot loops
Bug: Random restart and boot loop
A number of Galaxy Note 3 owners have reported random restarts where the device just reboots unexpectedly. Some unfortunate people have encountered a boot loop where the phone just continually reboots. It’s not entirely clear what is causing this. It could be something to do with apps trying to update, or it could be related to there being too many apps or services trying to start up.
It seems likely to be a software glitch of some kind and you would expect Samsung to release a patch to fix it, but there’s no telling how long that might take. In the meantime you could take your Galaxy Note 3 back to the retailer and ask for a replacement. Some people report the same issue with the replacement; others have suggested that their replacement model works perfectly.
There are others things to try.
Workaround:
samsung galaxy note 3 rear battery
Remove the battery and the SD card.
Put the battery back in and turn on the device.
Try Menu > Settings > Wi-Fi > Menu > Advanced and uncheck Always allow scanning.
Now you should be able to turn the device off and reinsert the SD card.
Boot it up and your problem might be gone.
Potential solutions:
You could remove the SD card, backup the data, put it back in the phone and try reformatting it via Settings > Storage > Format SD card .
If it’s stuck in a boot loop and you can’t get in to the main menu, you could factory reset the Galaxy Note 3 using the hardware buttons (but you will lose all data on it). Back up first if you can, and then:
Turn off the device.
Press and hold the Volume up, Home, and Power buttons.
When you see the Galaxy Note 3 logo, let go of Power.
When you see the Android System Recovery screen let go of Volume up and Home.
Press Volume down to highlight wipe data / factory reset.
Press Power to select it.
Press Volume down to highlight delete all user data.
Press Power to select it and wait until it’s done.
Highlight reboot system now and select it with Power and your device will reboot.
ciao ragazzi ,non avevo dubbi che prendavate il note3 dual sim ,ottimo acquisto,io per ora devo passare ,magari conl prezzo ribassato ci farò un bel pensierino ,intanto mi prendo la rom sva (grande) poi vediamo
I miei feedback TUTTI positivi su vari mercatini, su altri siti web e su ebay li trovate tutti QUI
..qualcuno saprebbe indicare dove poter acquistare dei tag nfc compatibili con il NOTE3; quelli dell'S3 non sono compatibili.
su ebay ho trovato diversi venditori ma non specificano che sono compatibili con il NOTE 3
Anche io sono interessato ma chiedi qui grazie
https://www.androidiani.com/forum/sa...-note-3-a.html
Ciao ragazzi, a breve dovrei essere dei vostri e siccome ci tengo particolarmente alla batteria vorrei cercare di preservarla il più possibile.
A tal proposito cosa devo fare quando mi arriva il note 3? Lo accendo, lo faccio scaricare del tutto e poi lo lascio sotto carica le classiche 8 ore?
E per i primi 3 cicli di carica conviene che lo faccia scaricare del tutto?
Grazie![]()
Se vi sono stato di aiuto, ringraziatemi con il tasto Thanks.
Ho avuto anche io questo problema... ho fatto un restore totale del telefono ed era scomparso, poi dopo qualche giorno si è ripresentato... brutta cosa...
Poi ho pensato di fare un boot in recovery e cancellare la cache un paio di volte, riavviato e da allora sono 3/4 giorni che è tornato normale.
