Pagina 868 di 1789 primaprima ... 3687688188588668678688698708789189681368 ... ultimoultimo
Visualizzazione dei risultati da 8,671 a 8,680 su 17884
Jiayu S3 - Modding
  1. #8671
    Androidiano VIP L'avatar di freedgt
    milano
    Oltre 180Mila.....Su Antutu
    Ringraziato 1,317 volte in 755 Posts
    ROM Title: Good domain S3_MIUI7_6.1.7 Developer Edition theme harmony / Account lockout / layout switching / support beautification Original Version switching / Advanced settings pure Beta 0111
    Suitable for: good domain S3 + high standard version
    Android Version: 5.1
    ROM Author: deciduous sad Xiangxi
    Reference Study: The End lib drive
    QQ Feedback: 718662473 / Please specify from forum
    Published: January 11, 2016
    Brush Method:
    1, you must first wire brush the official 5.1 system (if you are already 5.1 itself consciously ignored)
    2, you must use third-party Chinese recovery5.1 version (version 4.4 into the brush at your peril)
    3, 4 brush machine please clean are Dalvik Cache-System-Cache- internal cards (data partition)
    4, due to the Brush Script problem so for the first time the opportunity to open a little slower (about 10 minutes or so, but it will definitely boot)
    5, ROM packaged non-dat grid
    Like brush into plain version recommend watching the film version of MIUI, such as the original author mind, please contact me delete, thank you!
    Known BUG gesture can not be used with other NFC can not be tested. . . . Do not brush over mind! ! ! !
    [Official Update]
    [This week] recommended new waste disposal management capabilities add depth to clean up video installation package depth cleaning up garbage clean-up function modules
    【desktop】
    Repair using the theme "Snow Elf" unlock the desktop icons disappear brief question
    Fix the problem in some cases is not effective in applications Variety wallpaper
    【calendar】
    New applications recommended card
    ** New Card
    [Garbage clean-up]
    New deep clean installation package cleanup function
    Added depth cleanup video management capabilities
    Repairing Deep clean up large file size calculation problem
    [Modify] personal ized version flavor combined, heart switches the heart, ROM 2M only increase based on the original!
    Ized version or switch to optimize flavor, beautification / flavor swap arrangement is not lost, switching heart!
    (Without Shuangqing case) optimize the layout switching, brush set without losing the original layout, minus the tedious brush set the layout!
    Original version ====== =========
    * Add status bar time style (Optional Display Lunar + week + time, the Lunar + time, week + time, only was time)
    * Add status bar layout options (optional IOS layout imitation, imitation IOS layout and icons, the official default layout)
    * Add desktop icon layout options (optional 4X5,4X6,5X5,5X6)
    * Adding DPI density custom modifications
    * Harmonious personality theme, the theme of the arbitrary use of fees does not restore the default
    * Harmonious system writes to the SD card limit
    * Harmony Andrews core, signature inconsistencies can freely cover the installation
    * Modify ROOT authorization mechanisms, and kingroot optional automatic ROOT
    * Modify the default font, improve MIUI7 default font coarse problem
    * Adding desktop display weather, Lunar
    * Compile minimum brightness of 6
    * Removal minimalist mode
    * Removing unnecessary LIB library files
    * Removing infrequently used service items
    * Removing unnecessary font files
    * Removing infrequently used or unwanted software
    * Difficult to remove part of the ear ringing
    * Removal comes with wallpaper
    * Removal comes with test files
    * Removal of official comes REC
    Meihuaban ====== =========
    On the basis of the plain version, add the following landscaping
    * Dynamic stunning desktop clock widget
    * Chien boot animation
    * Set background and icon
    * Desktop Icon Size
    * Dialpad style
    * Pop style to fillet
    * Wallpaper and lock screen wallpaper
    * Notification bar and pull-down bar
    * Desktop Clock style
    * Volume adjustment Dropzone
    * System pop round
    * Lock screen style
    * Power percentage is displayed in the battery icon (! Note: If you do not have to, including battery, switch to IOS layout and icon)
    * More optimization capabilities into the brush at your own experience, not introduced one by one, thank you for your support!
    [Advanced Settings] [aid] application Hide
    - [Desktop icons hide assistant] key aide
    - [Instead of the bottom of the screen three-button] flash notice
    - [Incoming call / SMS / notification strobe flashing] color temperature adjustment
    - [Adjust color temperature, reduce the brightness] [layout] layout style
    - [Personalization system layout] [sound] Dolby sound
    - [Pro Logic Surround] Viper Sound
    - [HiFi-level auditory feast]
    [Note] 1. If you accidentally brush machine fails during installation, the installation can simply re-select the ROM!
    2. Do not modify before Brush ROM, it may cause the system can not work properly!
    3. Open Dolby sound too loud or break the sound Dolby Friends of the machine can be turned off or set to adjust yourself!
    4. Be careful unloading system comes with the application (non-promotion software), otherwise it will lead to not boot or other dysfunction!
    5. The ROM preloaded with a number of utility software, can be used Kingroot unloaded, I hope you understand!
    6. Part of the promotion after uninstallation process may cause residual FC, do not worry, the restart can remove unload residual data, non BUG!
    7. It is recommended that you do not delete the system comes with four default theme, after you remove the card may lead to such recent taskbar abnormalities or other problems!
    8. Be sure to use a third-party Recovery brush into the ROM, otherwise it will not brush into or other dysfunction, Friends of the machine will not see the forum, tutorials or plus group discussion!
    9. Custom DPI modify too small or too large may lead to not boot; 720P handset recommend 270-320,1080P recommendations 270-480, millet top version recommendations 480-640 Note! (As a recommendation only)
    10. The ROM default automatic ROOT, To manually authorize Please Kingroot page repair ROOT, Kingroot_4.6.2 version first use may install purification Masters, non-ROM virus!
    [Disclaimer]
    1. I have been tested by the ROM, as a result of improper operation of the consequences, and I've not and will not assume any responsibility;
    Please ensure that the battery has more than 20% of the electricity front 2. Brush, Brush process and to ensure that the mobile phone and computer without any exception, Brush process will continue 2-10 minutes, please be patient;
    3. Brush risk, the first brush machine, please read the forum Brush tutorials, or peril;
    4. He does not hold the copyright ROM and in the program, non-commercial use, please study and learning for the purpose of lawful use;
    5. I declare the various users of the ROM does not provide any guarantee, does not guarantee the suitability of the ROM does not guarantee trouble-free production; no guarantee of security and stability;
    6. nor use or loss of this ROM actually encountered any theory of liability for any user;
    7. Never tamper with the publication of my works! In particular, no technical content of the secondary packaging integrated promotion software, rights reserved!
    8. If you download and brush into this ROM, it means that tacitly accept this agreement.
    Please read carefully before jiyou ~ Download ROM presentation!
    Screenshot: Reference on the plate
    download link:
    Hide the contents of this post
    MIUI6.1.7 development ized (HDR originally usable, reinstall the system, the file is missing, the result can not be used, mind, do not brush!)
    JIAYU_S3_MIUI7_0110_beta4_luoye.zip_??????|??? ??-?????
    beta 4 luoye
    Oltre 180Mila Su Antutu.......
  2. I seguenti 4 Utenti hanno ringraziato freedgt per il post:
    egonfe76 (11-01-16),GIOBOT (11-01-16),metrino (11-01-16),pluffo (14-01-16)
    Sep 2013
    Salerno
    Newman k1 jiayu s3adv
    Ringraziato 69 volte in 48 Posts
    Quote Originariamente inviato da januarius Visualizza il messaggio
    Aggiornamento: ho installato la RC2 Kernel 31/12/2015 by Jiayu.de + Modem New UI 26/12/2015 by antonioa62 e le cose sono migliorate, adesso il traffico dati H3G non si impalla più come prima..
    Problema: quando effettuo una chiamata non posso navigare, anche avendo impostato tutto su una sim (dati + voce)
    posso ovviare a questo problema?
    Cia e grazie
    Io con scheda Wind nessun problema.In chiamata posso tranquillamente navigare.Però prima avevo il tuo stesso problema.Mi sa che da quando ho flashato il nuovo modem quello del 17.12 e con nuovo kernel del 31.12 si è risolto il problema.
    Ultima modifica di gipe77; 11-01-16 alle 19:30
  5. #8673
    Jan 2016
    Ringraziato 39 volte in 27 Posts
    [QUOTE=freedgt;7304371] Grazie solo cinese e inglese vero?
  6. #8674
    Senior Droid L'avatar di michiamanoLULUaccent
    Nov 2013
    Ringraziato 85 volte in 69 Posts
    la MIUI7_6.1.7 è quella che da ieri cerca di installarsi sul mio guerrino.
    Credo che sia la settimanale. Ma come è possibile? Un aggiornamento ota?
    Lo lascio fare e vedo cosa succede?
    Oneplus 5 e 7T soddisfatta
  7. #8675
    Oct 2014
    leeco lemax2 4g Jayu-S3A
    Ringraziato 567 volte in 345 Posts
    Quote Originariamente inviato da michiamanoLULUaccent Visualizza il messaggio
    potrebbe essere, fagli installare l'aggiornamento a limite fatti prima un backup ..
    aggiornamenti sulla mia miui stable,,
    onestamente me ne sono innamorato non riesco a trovargli nessun difetto.addirittura la batteria e' scesa al 0% senza spegnersi,. come ho detto stamane collegamento hot spot wifi di 2 ore e passa senza perdita di segnale..non sto qua a spiegare tutti i pregi d questa miui ci vorrebbe molto tempo per non parlare la possibilità di scaricare un miliardo e mezzo di temi ..incredibile da 10 +
    un thanks e' sempre gradito grazie
    leeco le max 2 rom 28S - M17r by CUOCO92 +
    JY-S3 advance NOUGAT RR-N-v5.8.5-20171227. by ANTONIOA62 TWRP 3.0.2.0
  8. Il seguente Utente ha ringraziato antonioa62 per il post:
    diego06 (11-01-16)
  9. #8676
    Senior Droid L'avatar di cicio71
    Sud
    JiayuS3A/Note2/AscendP6/Letv1s
    Ringraziato 109 volte in 88 Posts
    Quote Originariamente inviato da antonioa62 Visualizza il messaggio
    quale è la tua Antonio?
    quella di Becar?
    Samsung Note 4
  10. #8677
    milano
    QUESTA E DI OGGI la base e del 6 gli ota non penso siano compatibili con il nostro ma del redmi note 2 (magari sbaglio ma bisogna verificare)
    Ultima modifica di freedgt; 11-01-16 alle 20:19
  11. #8678
    Oct 2014
    Quote Originariamente inviato da cicio71 Visualizza il messaggio
    quella di Becar?
    no cicio e' questa stable a questa non ho fatto nessuna modifica rilevante , eliminato max audio messo titanium installato gapps e dolbi e il new ui modem ..tutto qua..gira na meraviglia
    nb devi anche mettere un app musica ti conviene copiarla nel system app quella di sistema e' un po ' problematica tutte cinesere..
    Ultima modifica di antonioa62; 11-01-16 alle 20:34
  12. #8679
    JY-S3S
    Ringraziato 148 volte in 107 Posts
    La fotocamera? Ma ha anche NFC e smartwake?
    Inviato dal mio JY-S3 usando Androidiani App
    JiaYu S3 Advanced JY-S3S --- (Rom LL 5.1.1 Germany (RC5))
  13. #8680
    Sud
    installo da recovery?
    le gapps come si installano e quali?
    Samsung Note 4
