Pagina 14 di 30 primaprima ... 4121314151624 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 300
[Guida] APK Multi-Tool: Come decompilare/compilare un APK
  1. #131
    Lodi
    THL W11
    riprovo riprovo ma nulla sopra ho messo il link dei 2 file con le 2 stringhe da cambiare puoi provare tu se va a buon fine
    Lodi
    THL W11
    ora mi da questo
    | Compression-Level: 9 | Heap Size: 512mb | Decompile : Sources and Resources Files | Current-App: framework-res.apk |
    HTTP://APKMULTITOOL.COM
    Simple Tasks Such As Image Editing Advanced Tasks Such As Code Editing Themers Convertion Tools
    0 Adb pull 9 Decompile apk 16 Batch Theme Image Transfer
    1 Extract apk 10 Decompile apk (with dependencies) (Read the Instructions before
    2 Optimize images inside (For proprietary rom apks) using this feature)
    3 Zip apk 11 Compile System APK files
    4 Sign apk (Dont do this IF its 12 Compile Non-System APK Files
    a system apk) 13 Sign apk
    5 Zipalign apk (Do once apk is 14 Install apk
    created/signed) 15 Compile apk / Sign apk / Install apk
    Install apk (Dont do this IF (Non-System Apps Only)
    system apk, do adb push)
    7 Zip / Sign / Install apk
    (All in one step)
    8 Adb push (Only for system apk)
    tools Stuff
    17 Batch Optimize Apk (inside place-apk-here-to-batch-optimize only)
    18 Sign an apk(Batch support)(inside place-apk-here-for-signing folder only)
    19 Batch optimize ogg files (inside place-ogg-here only)
    20 Clean Files/Folders
    21 Select compression level for apk's
    22 Set Max Memory Size (Only use IF getting stuck at decompiling/compiling)
    23 Read Log
    24 Set current project
    25 About / Tips / Debug Section
    26 Switch decompile mode (Allows you to pick to fully decompile the APK's or JAR's
    or to just decompile Sources or just the Resources or do a raw dump allowing you
    to just edit the normal images)
    00 Quit
    Please make your decision:9
    Decompiling Apk Sources and Resources Files
    Can't find framework resources for package of id: 2. You must install proper framework files, see project website for more info.
    "An Error Occured, Please Check The Log (option 23)"
    Premere un tasto per continuare . . .
  4. #133
    Lodi
    THL W11
    vi chiedo per favore almeno mi fate questa modifica mod
  5. #134
    enricocid
    Quote Originariamente inviato da cricu75 Visualizza il messaggio
    ora mi da questo
    (All in one step)
    tools Stuff
    23 Read Log
    00 Quit
    allora...
    1) apri il setup.bat e premi 3 per fare le cartelle
    poi 00 per uscire
    2) poi copi il framework-res.apk in place-apk-here-for-modding ed in other
    e il file da modificare lo metti in place-apk-here-for-modding
    3) apri il setup.bat e digiti 2 e poi 1 e ti installa il framework-res
    poi vai in prima pagina di questo thread e segui dal punto 1
    1) Mettere il file.apk da decompilare nella cartella place-apk-here-for-modding (lo abbiamo già fatto prima per il file di esempio framework-res.apk).
    etc etc
    se salti l'installazione del framework non puoi decompilare, tu la salti vai direttamente nello script.bat... fai i primi passi come ti ho descritto sopra poi passa in prima pagina e segui da
    Decompiliamo il nostro primo file.apk
    in poi...
  6. #135
    Lodi
    THL W11
    Quote Originariamente inviato da enrico2588 Visualizza il messaggio
    allora...
    poi 00 per uscire
    in poi...
    ma io lo faccio.....................*********************** ************************************************** *******
    * Installation of framework-res.apk Complete
    * Returning to Dependencies menu
  7. #136
    Lodi
    THL W11
    come sempre mi da questo --------------------------------------------------------------------------------------------------------------------------
    (All in one step)
    tools Stuff
    23 Read Log
    00 Quit
  8. #137
    Lodi
    THL W11
    ti chiedo per favore mi metto in ginocchio puoi provare tu con il link che ho messo, se riesci se poi va a buon fine domani formatto il pc non vorrei aver installato troppe cose o altro
  9. #138
    enricocid
    no.. io non posso fare mod... mi sono "ritirato" per un certo periodo e non ho piu i tool per farle
    ho fatto piazza pulita, cerco solo di dare supporto qui
    se qualcuno legge e vuole fargli il mod che chiede...
    mi scrivi il valore che hai messo in java_home delle jdk???
  10. #139
    Lodi
    THL W11
    JAVA_HOME
    C:\Program Files\Java\jdk1.7.0_45
  11. #140
    enricocid
    JAVA_HOME
    prima di premere 9 hai premuto 24 per selezionare il file da decompilare?
    se hai seguito tutto passo passo non saprei quale potrebbe essere il problema... magari lo stesso windows 8
    il framework? lo puoi postare in un archivio diverso dal .rar... tipo .7zip?
    altrimenti prova ad usare apktool direttamente [Guide] Decompile with Apk Tool [Easy Way] - xda-developers
    o questo dove c'é una versione per WIn8
    http://forum.xda-developers.com/show....php?t=2488693
    Ultima modifica di enricocid; 24-11-13 alle 22:01
  12. Il seguente Utente ha ringraziato enricocid per il post:
    cricu75 (24-11-13)
