Pagina 186 di 597 primaprima ... 86136176184185186187188196236286 ... ultimoultimo
Visualizzazione dei risultati da 1,851 a 1,860 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #1851
    Venezia
    S4 & G3
    Quote Originariamente inviato da Kraaker Visualizza il messaggio
    Oggi nuovo aggiornamento 204-71.
    Inviato dal mio Optimus 2X usando Tapatalk
    già, ha cambiato idea..... buon per noi! e ..... grazie Temasek
    CHANGELOG ( Also for N1 P253-66 , P970 P20-56 )
    MERGED COMMITS UP TO
    Change I31db76c5: Fix make-kexec-cwm-test-zip.sh to find, strip and use the unstripped update-binary
    http://review.cyanogenmod.com/#q,sta...ingerbread,n,z
    Notable Merges (Not in my cherry-pick list)
    - Change Idea50432: memmove: Fix the abuse of memcpy() for overlapping regions
    - Change Icc4957c0: update OI File Manager 1.1.6
    - Change I2c489975: Toolbox implementation of chown has a bad print
    - Fixed commit ac8521c5f94249a33ad7ba870467904b08904101
    Ensure that "*cover*" or "*front*" matched file has proper extension (jpg or png).
    This fixes issue with media files containing "cover" in their name - "Smoke On The Water (Deep Purple Cover).flac"
    With no embedded album art nor albumart.jpg file, the audio file was treated as an image.
    - Change I3c7469b8: Allow maintainers to restore pre-I7ab734c behaviour
    CHERRY-PICKS
    If you see any picking is missing from last build, it is because it was merged, abandoned, reverted by me or I've eaten it up.
    MERGED - Change I77f3c6e8: Add build date to 'About phone'.
    MERGED - Change I3be41b9f: Fix STARTTLS handshake error in Email's SmtpSender class (GB)
    MERGED - Change I80992880: Add ARMv7 optimized strlen()
    ciao ragazzi oggi essendo domenica mi sono messo un ò a moddare il dual...partivo da una kang .66 e kernel lge 120113 (presente nella prima pagina della.discussione.... ho messo la kang .71 e kernel etana loc 32mb hack....risultato?????!!!! La rom era peggiore..il sensore luminosità andava malissimo.. modificava la luminosità spesso e cn scatti...inoltre il kernel etana facendo vari benchmark prendeva sempre in antutu punteggi minori su ram e cpu (a parità di frequenza rispetto al mio precedente kernel lge 120113....morale....sono tornato al mio kernel preferito....il migliore....in prestazioni consumi e stabilità ....
    Ultima modifica di brutal986; 04-03-12 alle 18:39
  4. #1853
    Quote Originariamente inviato da Miryel Visualizza il messaggio
    la batteria è funky perchè il driver DS aggiorna meno frequentemente i valori della batteria per cui legge valori errati, ma in questo modo risparmia un casino di batteria, purtroppo bisogna tenerselo non c'è modo di fixarlo al momento (a meno che qualcuno non ci metta mano, ma leggo che ci vuole esperienza e vadonka non riesce al momento)
    Quindi é normale che spesso da percentuali più alte senza metterlo in carica?
  5. #1854
    Senior Droid L'avatar di Miryel
    Novi Ligure
    LG Optimus 2x
    Ringraziato 50 volte in 36 Posts
    Quote Originariamente inviato da disti Visualizza il messaggio
    il mio invece di scendere sale
  6. #1855
    Il mio con dati attivi, rete 3g, wi-fi e dati in background, oscilla intorno al 50% dopo quasi 15 ore. Spero non si spenga all'improvviso. Comunque sia é un gran kernel molto meglio dei precedenti.
  7. #1856
    Venezia
    S4 & G3
    E io, invece, sono tornato a quello del 20/02. L'iron non andava male ma come consumi trovo migliore l'etana.... solo non ricordo se era questo, o quello del 18.... o adirittura quello del 22.. farò alcune prove...
  8. #1857
    Androidiani Power User L'avatar di Gerryb182
    ๑۩ﺴ♥RIMINI♥ﺴ۩๑
    ° Gs2-Gs4 OctaCore-Gt2 7" °
    Ringraziato 4,889 volte in 2,566 Posts
    Anche il mio, se sotto stress esempio "giocando", la batteria scende, poi andando in stand-by risale
    uso l'Etana 0Hac del 22/2 è non ho nessun problema...
  9. #1858
    Androidiano L'avatar di GibeBolone
    Ciao a tutti, seguo anche io
  10. #1859
    Senior Droid L'avatar di MaNFr3
    Lecco
    LG P990, Nexus 7
    Ringraziato 34 volte in 28 Posts
    io ho fatto due notti di test: 7 ore con tutte le applicazioni in background interrotte (197mb liberi) con il kernel Iron da 32 e quello lge della cyano. Col primo la batteria mi è scesa dell'11% (accettabile se non fosse per il fatto che quando ho ripreso a utilizzare il cellulare crollava a vista d'occhio) mentre con il secondo solo del 4%.
    codice:
    Nexus 7 (Wi-fi) 16Gb:                            LG Optimus 2X:
    ROM: SmoothROM V5.0                              ROM: PA 2.6
    Kernel: M-Kernel mr1                             Kernel: Kowalski Kernel 100p5
  11. #1860
    Venezia
    S4 & G3
    Quote Originariamente inviato da brutal986 Visualizza il messaggio
    infatti è il kernel che ho maggiormente usato.... cercherò di capire qual'è il migliore tra le versioni del 18, 20 e 22 e poi farò il confronto con quello del 13.
LinkBacks (?)
