Pagina 40 di 162 primaprima ... 3038394041425090140 ... ultimoultimo
Visualizzazione dei risultati da 391 a 400 su 1613
[INFO] Sudden Death galaxy S3 ( Morti Improvvise)
  1. #391
    Androidiano VIP L'avatar di molochgrifone
    Ringraziato 390 volte in 331 Posts
    Quote Originariamente inviato da csrurt Visualizza il messaggio
    Ultimo aggiornamento di AndreiLux da XDA:
    "The fix is some MMC command magic and it is a soft-patch that's applied on every single boot or MMC resume. You will not be safe on kernels without it (People will have to use updated recoveries too!). The phones affected are as previously theorized only the ones with VTU00M memory chips."
    Arrivo ora a questo thread, e verifico subito il mio chip, ovviamente VTU00M, prodotto ad aprile 2012.
    Esiste un thread che indichi come mettersi al sicuro, in caso di cellulare moddato/rootato, ed aver certezza della riparazione in garanzia e che magari riporti info utili, ammesso e non concesso che al momento ci siano certezze?
    Aggiungo da XDA, thread kernel perseus, l'update di oggi che è significativo:
    Perseus alpha31 (09/01):
    Removed my own security fixes and replaced them with the official Samsung one. I guess it can now be disclosed: exynos-mem was only one of multiple entry-points for the memory exploit. We discovered the s5p-smem exploit ourselves back in December but kept it quiet, I fixed that one back in version 29.2 without mentioning. Nobody was secure from a smart exploiter up until then, SuperCurios or Chainfire's software fixes are also just patching a single hole in what is a Swiss cheese. Kernels >v31 and beyond stock LLA are now the only truly protected ones.
    Samsung's fix for the sudden death syndrome (SDS) included. It is caused by eMMC failure on phones with VTU00M internal memory chips with revision 0xF1. You can check your phone with the "eMMC Brickbug Check" in the Play Store (Ignore the message if it says you're not affected, the type and revision is what matters). The patch is a firmware soft-patch that is applied on every boot and MMC resume, it is not a permanent fix. You will need to stay forever on kernels which include the patch, this also will include updated recoveries.
    Some other minor MMC changes extracted from Update 7 sources.
    Harmonized some mif/int max voltages with the Note 2 limits.
    Ultima modifica di molochgrifone; 09-01-13 alle 11:31
    Il tasto thanks non ha mai ucciso nessuno
    Baby Droid L'avatar di Yoji
    Quindi è a rischio anche il mio note2...
  4. #393
    minchia ci sono dentro anche io! preso un mese fa il S3, ho la 4.1.2, ma no XLAA... il programmino del check mi dice che ho tutti i requisiti per essere fottuto O.o
  5. #394
    Jun 2010
    Samsung Galaxy Note Edge
    Ringraziato 64 volte in 61 Posts
    Con "*#12580*369#":
    RF cal. 2012.7.5
    HW Rev. MP1.100
    preso il 4 settembre dalla tre....
    Samsung Galaxy Note 9 8GB - 512GB Midnight Black + Regalo microSd 512GB xc Samsung
    Samsung Galaxy Note 8 6GB - 64GB Midnight Black
    Samsung Galaxy S3 blue
    Motorola Photon 4G
    Motorola Milestone
  6. #395
    Aug 2009
    Exclamation
    Modello: Samsung Galaxy S3 - Blu, acquistato con Wind
    Acquisto: 10/11/12
    Brick da solo dopo carica overnight: 22/11/12
    Inviato in assistenza il 08/12/12 Rientrato da assistenza il 31/12/12
    Assistenza Samsung lo dichiara MANOMESSO E FUORI GARANZIA, perché in Odin mode "system status" = custom. Me lo rimandano indietro.
    Non entra in recovery, quando mi è tornato ho provato deep clean 1 e 2, niente .pit, morto che più morto non si può.
    Non ho fatto root, non ho installato alcun firmware. Solo aggiornamento Jelly Bean ufficiale tramite Kies, dopo il quale ha funzionato normalmente per giunta, fino al 22/11/12.
    Non so cosa fare, sto litigando con SamsungExclusive, ufficio reclami, call center. Inutile.
  7. #396
    Ringraziato 61 volte in 52 Posts
    Anche io stesso chip..
    Ma su sta cosa c'è quslche certezza o è l'nsima ipotesi?
  8. #397
    Quote Originariamente inviato da JaBaWaCk Visualizza il messaggio
    Acquisto: 10/11/12
    Ecco, questo è altamente preoccupante.
  9. #398
    sinceramente qui è tutto preoccupante, poi io ho un terminale che mi hanno regalato e lo scontrino il donante non se lo trova più :°°(
  10. #399
    Ciao,
    leggendo su X D A sembra che la omega 31.2 risolva il problema,
    domandina newbie... qualcuno sa se si tratta di una rom Modded, o è una componente da installare separatamente tramite Odin ?
    Mi sembra di aver capito che è una patch che viene applicata in automatico ad ogni boot di Android e previene la morte.
    Ovviamente mi sto già chiedendo questa come patch impatterà su eventuale garanzia
    se S3 dovesse andare in riparazione per altri motivi naturali.
    Grazie.
    Frx
    Ultima modifica di ferrux61; 09-01-13 alle 13:30
    concluso positivamente con gilbo666
  11. #400
    Androidiano L'avatar di wolf86
    Trento
    Galaxy S III
    Acquisto: 10/11/12
    Ciao ho letto il tuo problena se sei un po smanettone posso aiutardi afarlo ripartire pero perdi alcuno gb di memoria
    Quote Originariamente inviato da wolf86
    Acquisto: 10/11/12
    Scusa ma non riesco a scrivere con la nuova swiftkey
    Ultima modifica di dieguccio; 10-01-13 alle 15:49 - Motivo: doppio post
